I looked in the fuse box on my 04 Intrepid and found the fuel pump relay but where is
the fuel pump fuse ?
THANKS
Theirs a panel on the left side of the dash. You access that one by opening the driver's side door and gently pulling the panel off.
Welcome to the site George.
Bitches be like...
although, Fuse 13 in the junction block does also route power to the Relay in the PDC, and from there to the powertrain control module. So if you are chasing an issue check that one too. That relay gets it's ignition position signal through that fuse on the junction block. The power going through the relay to the fuel pump itself is definitely coming from fuse G though.
