I ripped the o-ring that goes from the fuel supply into the fuel rail. Dodge says they don't sell the o-rings seperately and that I can buy a whole new fuel rail instead. Not for $300.00!!!!
Around town the only o-rings I can find are made of Neopren. The o-ring size is -108.
Does any one know what the blue o-ring material is that Dodge uses?
I had to order 50 o-rings from McMaster. I order Viton since it will hold up against gasoline.
Any ideas? I was told by several people that the blue material that Dodge uses is a heat/gas resistant material.
Thanks.
Hardwarz
"Recall 98V184000: Fuel Rail/Injector O-Rings Leak...........
.......Dealers will replace the nitrile rubber O-rings in the fuel rail with fluorocarbon O-rings. If the fuel injector O-rings leak after pressure testing, the injector O-rings will be replaced as well....."
That help at all?
Discussion Starter · #4 ·
Looks Good
Looks like I did good then. I orderd Viton o-rings.
This is from the McMaster website:
Viton (fluorocarbon) O-rings offer a wide spectrum of chemical compatibility and temperature-range adaptability. Use with petroleum products, diester lubricants, silicone fluids, solvents, and acids (except fuming nitric). They have good resistance to taking a set after compression, and low gas permeability. Great for hard vacuum service. Not for use with acetates, methyl alcohol, ketones, brake fluids, hot water, or steam. Durometer is Shore A: 75; temperature range is -31° to +400°F (except metric sizes, which have a temperature range of -15° to +400°F). Inch sizes meet ASTM D2000 MGHK810A1-10B38EF31Z1.
Ok, so what am I going to do with the other 49 o-rings?
Hardwarz
You can buy the recall kit for like $30.
Comes with all the o-rings for the fuel rail.
The injector o-rings come in another kit I don't remember
what that cost.
p/n 05069022aa rail kit
p/n 0514076aa inj. kit
