I want to thank everyone again for helping us put in the timeing belt in my "94 Intreped.
We know have a new problem. Since doing this my Gas Mileage has gone from 20 + MPG to 13 - MPG
I have no idea on how to correct this, so really need your help!
Thank you again!:confused:
Is this according to your OTIS.
Mileage computer readings?
Disconnecting the battery will reset the "AVeraGe" miles per gallon.
Speeds between 100km/hr - 110km/hr. Usually display an instant reads of 8 to 9L / 100km's.
Well, not knowing too much about what you did when you repaired your car, I would have to say maybe the timing isn't set correctly? I don't know. I am assuming you just removed the radiator, pulley, timing cover and replaced the belt. The marks are supposed to be situated a certain way for correct timing. But on the other hand, the car seems to be running OK so maybe I am off. That is a huge drop in mpg's though.
Use the search button........You'll find all kinds of things.
It runs perfect except for the Gas mileage...I got could mileage before.??????????????????????
