"Successful" swap from a blown 2.7 to a 3.5HO. Engine runs smooth, and car drives fine. However, several problems persist.
Problems:
Tachometer and Spedometer not working (they do light up however and the gas gauge DOES work)
Shift Display (does not identify what gear you are in)
Data Link Connector not working (getting LINK ERROR on simple OBD readers, and cannot communicate with PC-based reader)
Warning lights on: ABS (my SE does not have ABS, so this remains disconnected), Airbag, e-brake, Check Engine
My car: 2002 2.7L SE (not autostick)
Donor: 2000 3.5HO R/T (autostick)
3.5HO parts installed in the Engine Bay:
engine & transmission
PCM
TCM
Power Steering
Radiator/condensor/fan
AC lines (had to alter some old 2.7 parts to fit with the 3.5 but all is well)
3.5HO wiring harnesses
3.5HO parts installed in the Interior:
BCM and housing
Gauge cluster
My biggest frustration is being prevented from reading the codes through the data link connector. I have not found any fault in a connection and the data link wiring itself routs through the 3.5HO BCM, which is connected into the engine bay using 3.5HO wiring. made things even worse.
I'm also concerned about the lack of tach or speed. Anyone ever fix this easily or should I just replace the gauges altogether?
I'd appreciate any help on this one - I'm kind of at a loss as to where to go from here.
I think were your main problem is that you put the wrong engine in there. Since your car is an '02 alot of the internal wiring changed between the 2000. Unless you re-did the whole wiring harness in the engine bay and inside the cabin I would say that's your problem.
Another possibility is that the cluster is not instaled properly so all the pins are not makind conection. Also, you said that you instaled the guage cluster from the R/T? Try instaling the one from your trep.
I've tried both gauge clusters. Actually, nothing works at all on the 2.7 gauge cluster.
You're right on with the "wrong engine." But I have swapped all wiring because of that. All the wiring in the engine bay is 3.5HO. I've routed the 3.5HO wiring from the PCM/TCM in the engine bay to the 3.5HO BCM within the car. That feeds a 3.5HO gauge cluster. So I've tried so stick with all the specific make and model's parts. We've taken both entire dashes out of the 2002 and 2000, and verified that they are actually identical in every way. The wiring did not need to be changed in that.
Also, keep in mind there's something different about the gas tanks between the years. The BCM's also changed so I don't know what kind of impact that would have since you didn't change the dash harness. The men to talk to about this would be TFC or Daytrepper. Daytrepper acutaly did a complete wiring swap from '98 to '02 specs on his car and would know were you could have went wrong.
Thanks a lot. We've got both dash harnesses, so that can be done as well.
Hell, it might have been easier to put the body of my car onto the chassis of the donor car (it had one entire side and trunk hit).
No need to swap all that. I suggest going back to the 2.7 computers. If you put the 2000 computers in the 2002 car, and didnt swap all wiring in the entire car, that is likely why you are getting the errors, because not everything is compatible. Re-install your 2002 BCM and PCM, and harnesses, convert the engine to 02, and that should solve the problem, and give you much better results (including special PCM capability) then you would get with the current setup.
Check the link below, this all that needed to be done to the engine to make it run on the 2002 electronics. Hate to say it, but nothing at all needed to be replaced on the car.
http://www.dodgeintrepid.net/forums/t76738/
If nothing else, its about the same amount of work..., swap the body harness and dash harness, fuel tank, and emissions components in your 00 car into the 02 car, since youve gone this far already...but you will lose the advantages of the 02 stuff.
