For those who don't know. There is a way to get the troubleshooting codes from your onboard computer without a scan tool.
Turn the key foward three times to the on position (Not run position)with in 5 seconds. This will flash the codes on the odometer. Go to www.ALLPAR.com to find out the meaning of the codes.
I did it this morning because my check engine light came on. It simply said the battery was disconnected within the last 50 starts. Which was true because I cleaned the terminals last night. I know from experience the check engine code here will clear in 48 hours.
Hope it helps.
Hope it helps.
