Howdy!
I'm from eastern Montana and came here to find info to save my '94 Intrepid, aka "The Crazymobile". Why "Crazymobile"? Well, one day the grandson asks, "Where you going Grandpa"?, and I reply, "Crazy, ya wanna go with"? Of course he says yes, so I tell him, "OK, go get in the Crazymobile". The name has stuck for years and the kids love the care as much as I do. So, I gotta save the Crazymobile.
Thanks for this resource and thanks in advance for your help.
OK, after poking around here for a while, I can't seem to find where to ask about doing a 1G engine/transmission R&R. Please point me to the correct thread.
Pretty straight forward far as any trans sway goes. remove and replace!
Note however-
Cv axles can be a total PITA to remove from the stub shafts.
Exhaust has to be dropped, and unless you have a lift that means you have to cut it o remove it enough.
If you can, swap along the TCM (Transmission Control Module) since the newer-working trans has the CVI (clutch Volume Index) saved. 93-95 tcm work fine in any LH vehicle.
Otherwise all plug/play
