1 - 9 of 9 Posts
hey guys i went to the junkyard today and i found a jeep grand cherokee with the steering wheel controls, i pulled out just the buttons and the harness. they look the same as the ones from the 2001+ intrepids and 300m's. the thing i'm wondering is if these would work if i got a proper clockspring and just cust some holes in the back of my steering wheel and put these in. I've read a bunch of threads about this and i'm also wondering, can i wire the radio controls straight to the input on the back of the radio or do i need to run them to the bcm first, and then connect the pci bus wire to the back fo the radio? and if i do need to run to the pcm, will my 2000 ES bcm work with steering controls?
They should work but you do need to go to the BCM, it is what deciphers the button "signals" and send the requests to the radio via the PCI bus.
TERMINATOR101CA said:
I thought that steering wheel controls would work only in 2001 or newer... :sheep:
That too is true, never noticed the car was a 2000, just the reference to the 2001 in the question, my mistake.
what if i was able to get a 2001+ bcm just to control the steering wheel controls? like as a secondary bcm? I believe someone was selling a set-up like that a lilttle while ago that included the steering wheel controls and a bcm to control it.
They're different !!!!! In 2001+ the BCM has the TCM integrated whereas the 2000 and earlier have them as separate units !!!!
i know the bcm is different, i don't want to replace my bcm, i want to add a secondary one with only power, ground and radio controls connected, and run a separate pci bus to my radio
Ask Gorm, that was what he did a while ago, and I think it was him that had it for sale.
1 - 9 of 9 Posts
