1 - 15 of 15 Posts
I recently aquired a 2002 Chrysler LH Parts Catalog if anyone needs a part number. Also can provide numbers for LH models back to 1994 from another parts catalog.
Please post your request here on the board so that everyone can benefit.
Autostick shifter and black bezel for 96-97. Autostick guage cluster for 96-97.
Thanks.
My pre-2002 parts book is a Mitchell's collision guide, and it does not list EVERY part. It only lists those items that could get damaged in an accident.
There is no listing for the shifter, but the AutoStick console bezel is KJ48RAZ and the AutoStick gauge cluster is 4798212.
Your dealer can give you prices on these numbers and a number for the shifter.
ADDITIONAL INFORMATION 6/3/03
The AS gauge cluster is made up of the following parts:
Lens and Mask - 4798212
Board (120 MPH and AutoStick) - 4761428
Board (240 KPH and AutoStick) - 4761429
You would use the board that is appropriate for your country.
ADDITIONAL INFORMATION 6/3/03 for 1997 Autostick cluster
CiscoKid said:
1998 Body Control Module (BCM):
Base - 4759532AJ
Premium - 4759534AJ
Actually the current part numbers are:
Base - 4602282AH
Premium - 4602284AH
A foot note here, BCM'S are ordered on an exchange basis, meaning you bring yours in and it is sent out to be basically remanufactured.
If anyony needs current numbers and pricing I have my dealer connect software on my home computer. I can look up parts and availability around the country.:cool:
Moparpartsguy -
Thanks for the info - the date on my catalog is February 27, 2002. What is the date on your dealer connect info?
Your base numbers are lower than what I show and your revision letters are lower as well for the BCM. ?????????????????????
My dealer connect is a connection into the Chrysler computers so it is as current as possible.
The revisions are lower du to the part number change and the new numbers have gone from AA to AH so far.:)
Also don't go by the higher or lower numbers I can tell you from my experience at Chrysler there is no rhyme or reason to the numbering system.:crazy:
Discussion Starter #11
Sure enough, the BCM numbers superceeded about 10 times since the listing in my book.
If this is characteristic of electronic parts and modules, you may want to go to Moparpartsguy or your dealer for these parts.
Not sure if you will be able to find this one, but...
Is the 2nd gen transmission chain the same part number as the 1st gen? If its different, whats the 2nd gen part number?
Thanks again.
Thanks guys.
1 - 15 of 15 Posts
