1 - 9 of 9 Posts
Hey there i have an 02 Intrepid SE model so it didnt come with fogs, is that an easy install or will it take a professional to do it
Bitches be like...
the main problem with the stock fogs is you'll have to replace the whole bumper cover. If you get one from the yard just grab the fog harness with it. You'll also need the headlight switch.
I've seen people just cram aftermarket rectangle ones in the SE grille. Those would just get wired up per the installation manual.
i was thinking the es bumper cover with aftermarkets so i can wire it from there with a hole precut.. they would stay on with the car right?
I've never done it, but I thought it was a pretty straight-forward swap, provided you can find the proper bumper, lights, and wiring harnesses at a junkyard.
Need that OEM wiring harness!
1 - 9 of 9 Posts
