Just got back from Mr. Lube. I have just had the FULL transmission fluid change including the flush, pan cleaning, filter and gasket change also (i don't know what that is, actually). Total is CAD$193.00.
Hope my car runs good.
Ouch, well not too bad canadian wise. They used atf +4 i hope.
Nop, they use ATF +3.
I have asked for +4. However, they said that +3 and +4 has just some minor difference. The main point is if the car likes it.
ATF +4 has many more anti-foaming properties, as well as better anti-wear and anti-corrosion properties. It is a better overall fluid in many ways. Not that you can really change that now.
I see.
By the way, just noticed from your signature. You have relocated the cruise control button to transmission shift button! That's a really cool idea!!
