I was changing out my stock halogen bulbs on Saturday for some Sylvania Cool Blue ones. Anyway, I was taking off the headlamp like my Haynes manual told me to and I had a problem. It appears that the torx screws and nuts they use crack the plastic housing frame that holds the light into place. I was shocked that every one of them that I tried I broke! I then looked at the other light and it appears that someone else also did the same thing. I think the nut on the bottom of the housing that is apparently molded into the plastic ceases to the screw and the twisting breaks the plastic before unloosening the nut. Everything turned out OK thanks to my engineering abilities (hee hee).
Has anyone else had this problem? This is nuts, my car isn't that old. How much for new brackets??
