Hey guys,
I changed my spark plugs, wires, and coil pack yesterday. Much to my surprise tonight when I flip on the headlights and foglights, nothing happens. The dash lights up and the blinkers work, and the high beams work when activated via the steering column, but when I use the headlight switch, the headlights and the foglights do not turn on. Could I have bumped something lose when I changed the spark wires? I checked the fuses also, all good? What do you think? I am puzzled. TIA
try a junkyard, get another headlight switch, it might have failed, it may be unrelated, just bad timing
also just for ha has pull the turnsignal switch, since everything goes thru it
Bad multifunction switch. I could even bet on it.
yea, but they'll run you over $100 at AZ, junkyard should only run $10-15 for an MF switch (aka, misc part)
