Hello all! I just got ahold of a '99 300m this is in addition to my '99 intrepid es
I've done work on the seats in my intrepid, and now I have an issue with the seats on the 300m, specifically the heat feature, I looked up the service manual, and it says that if the LED comes on but the heating element doesn't heat, one should check the circuit breaker in the junction block....pretty clear, but where is the junction block? if anyone knows I would really appreciate the info. Thanks in advance for any help
The junction block is the fuse panel behind the left side of the dash, there is a little access cover when you open the door. Also if you heated seats aren't working but the light is coming on it could mean a burnt out heating element. In which case you can by an overlay from chrysler to replace it.
