Just like the title says, my blower is stuck on maximum...I can turn the heat or ac up and down to adjust temperature, but I have only one blower speed. And I can't even turn it off.
This is on a 97 Intrepid ES with automatic climate control.
Does anyone know an easy fix for this? My local mechanic says he usually has to replace the entire until with a junkyard unit that runs $80 (which is more than the whole car is worth about now)
I wonder if there is a quick or temperary fix for the switch...or even a way of simply wiring in an On/Off two position switch for the circuit.
Thats a bit high. here in ny there $20 at the yard. take yours apart and clean the contacts with alcohol and q-tips. Clean the circuit board good. on the rotary manual one u might have to bend the arms inside to let it make contact with the board. Use a pencil eraser on the board to get the contacts surface back to life. Check for bad soldering connections. If the connections have a dull look redo the soldering. If they have a shiny look look closely and make sure there arent any cold solder joints.
Sounds likes the blower motor resistor is shot. That would be the first thing you want to check, and a lot cheaper to replace with a new part than the whole switch. Rarely does the switch go bad. If the fan motor only blows on high that's most likely your problem.
