1 - 2 of 2 Posts
I'm working on converting all my driving lights to hid! The low beams work without a problem but the high beams will not! I switched the out put wires on the ballast with the low beam and the hi beam bulbs will light up so it's not the ballast I also switched the input of both ballast and the one with the low input works in any combination! I can also plug the helogen bulbs back in and they work!!!!!!? Any ideas I still have the fog lights to go will I have problems with that to?
1 - 2 of 2 Posts
