how do you get to the battery to connect the power chord for amp installation and where do you run the wire under the hood? I need to know ASAP im putting it in now
You can remove the airbox to get to the top of the battery or you can just connect to the jump terminal. Then you have to run the wire through the firewall. The easisest place to get through the firewall is through a grommet on the driver's side. There is instructions in the 2nd gen how-tos.
