My shifter cable on my 99 Intrepid was getting difficult to move. Had this problem before and had the dealer replace the shift cable because it was rusted. Well same thing happened a few months ago it started getting difficult to shift again. So to save my self 500.00 to replace a 85 dollar cable I elected to do it myself. Well I bought the new cable and just spent the last 5 hours under the car with my arm wrapped around the sway bar covered in grease and dirt unbolting the 13MM bolt holding the cable bracket to the transmission. after 4 hours of :banghead: I finally get the new cable attached to the shifter mechanism and screwed the stupid little STINKIN 13MM bolt back in turning it 1/16 of a turn at a time because of ZERO CLEARANCE THAT STUPID DMC MADE BETWEEN THE BOLT AND THE TRANNY DIPSTICK TUBE. Anyway I get it all strung through the firewall and I go to attach it to the steering shifter and I find that they gave me the wrong DAMN part. The part of the cable that snaps into the steering column bracket that is held by a flat spring clip is not correct the one I took off is just a round collar with 2 groves in it and you slide it into the metal bracket and slide the clip onto it to hold into place. The new one has a plastic piece that has snaps on it and will not slide into the bracket.
I AM SOOOO PO'D I cannot see straight. Does any one know if I can just change the bracket on the steering column instead of wasting another day returning the old cable for a new one and replacing it all again????
I am seriously comtemplating just driving it to an open field and setting the damn thing on fire and not bother to even collect insurance.
