Hey All I'm New To The Group.
I Have The Following Codes Come Up:
13 MAP sensor pneumatic circuit.
33 A/C cutout relay circuit.
What Do These Mean?
How Can I Fix Them?
Thnx Alot,
J.C.
MIL Code
Description of Diagnostic Trouble Code
12*
Battery has been disconnected within last 50 key-on cycles
55*
Completion of fault code display on Check Engine Lamp
54**
No camshaft signal detected during cranking
53**
PCM Internal Fault detected
47***
Battery voltage sense below target charging during engine operation
46***
Battery voltage above target charging during engine operation
42*
Open or shorted condition detected in the auto shutdown relay circuit
41***
Open or shorted condition detected in the generator field control circuit
34*
Open or shorted condition in the Speed Control vacuum or vent solenoid circuits
33*
Open or shorted condtion detected in the A/C clutch relay circuit
32**
Open or shorted condtion detected in the EGR transucer solenoid circuit
31**
Open or shorted condtion detected in the duty cycle purge solenoid circuit
27**
Injector #3 or #2 output driver doesn't respond properly to the control signal
25**
Open or shorted condtion detected in one or more of the idle air control motor circuits
24**
Throttle Position Sensor input above/below acceptable voltage limits
22**
Engine Coolant Temperature Sensor input above/below acceptable voltage limits
17*
Engine did not reach operating temperature within acceptable limits
15**
No vehicle speed sensor signal detected during road load conditions
14**
MAP sensor input above/below acceptable voltage limits
13**
No difference recognized between the engine MAP reading and the barometric (atmospheric) pressure reading from start-up
11*
No crank reference signal detected during engine cranking
43**
Peak primary circuit current not achieved within maximum dwell time (could be on ignition coil #1, #2 or #3)
42*
Open condition detected in the ASD Relay Output Circuit
32**
Required change in air/fuel ratio not detected during diagnostic test
62*
Unsuccessful attempt to update EMR mileage in the PCM EEPROM
63**
Unsuccessful attempt to write to an EEPROM location by the PCM
23**
Intake air temperature sensor input above/below acceptable limits
16*
Knock sensor either shorted to ground or 12 volts. Will not detect open circuit
61
Barometric pressure out of range
27**
Injector #4 output driver does not respond properly to the control signal
53**
PCM internal fault detected
27**
Injector #5 or #6 driver does not output does not respond properly to the control signal
77*
Malfunction detected with power feed to speed control servo solenoids
34*
Speed control switch input above/below acceptable voltage limits
33
A/C pressure sensor input above 4.9 volts/below .098 volts
35**
Open or shorted condition detected in the control circuit of the low/high speed radiator fan
66
No messages received from Transmission Control Module / No messages received from Body Control Module
42*
Open of shorted condition detected in the fuel pump relay control circuit
43**
Misfire detected (hook up scan tool reader to determine which cylinder)
31*
Insufficient or excessive vapor flow detected during evaporative emission system operation
37**
Incorrect input state deteceted for the Park/Neutral switch
52**
Rich air/fuel mixture has been indicated by an abnormally lean correction factor
51**
Lean air/fuel mixture has been indicated by an abnormally rich correction factor
17**
Engine does not reach 20°F within 5 minutes with a vehicle speed signal
24**
TPS signal does not correlate to MAP sensor
14**
5 volt output to MAP sensor open
45**
Automatic transmission input DTC has been set in the transmission controller
25**
Actual idle speed does not reach target idle speed
71**
5 volt output from regulator does not meet minimum requirement
42*
Open circuit between PCM and fuel gauge sending unit / Circuit shorted to voltage between PCM and fuel gauge sending unit / No movement of fuel level sender detected
65**
No release of brake switch seen after too many accelerations
44**
Battery temperature sensor input voltage above/below acceptable limits
11**
Intermittent loss of either camshaft or crankshaft position sensor
72**
Catalyst efficiency below required level
21**
O2 sensor
11**
CKP sensor target windows have too much variation
21
Oxygen Sensor reponse slower than minimum required
* - Check Engine Lamp will not illuminate if this Diagnostic Trouble Code was recorded. Cycle Ignition key as described and observe code flashed by Check Engine Lamp
** - Check Engine Lamp will illuminate during engine operation if this DTC was recorded.
*** - Generator Lamp illuminated
This is under How-To's
http://dodgeintrepid.net/forums/showthread.php?t=9477
Does anyone know why I get 4 flashes, a long check engine light, 4 flashes, a long check engine light, and 4 flashes at the end of the code cycle? The codes I get from it otherwise are 12 and 21, but this pops up and its puzzling.
