i there some kind of secret for getting out those headlight screws that hold the headlight housing in on my 96 intrepid .They are striped or something they just keep spinning!!Can any1 can help!!!:mad:
just a quick question, are you turning the torx head screws or the adjustment screws. they have been known to stip out as well.
i am turning the torx head screw .It just spins!do you have any ideas to get the screws out without replacing the whole unit?
This is a common problem with 1st gens, when I had my 97 Vision I removed the headlights at the three aiming posts. it's a little tricky but it worked. You have to get a bent needle nose pliers, it's harder with a screw driver, and turn the ball end till the three tabs line up to the three openings.
