99, 2.7L ~ 130,000 kms..
Engine at curb idle runs rough. The CEL is back on and getting a code 0303, which I think is a misfire detected in cylinder 3. I have installed new plugs and problem is still there. Next I put in a new IAC motor. Still there. With the engine running I started unplugging the coil pack wires one by one. You can hear and see a noticeable drop in the idle on all including number 3, although not as pronounced. I swapped cylinder 3 and 5 coil packs and no difference. I'm stumped. Last time I took it to the dealer they had to swap out one sensor at a time until they found the bad one, not the same problem at that time. I'm not made of money and can't afford to replace the sensors until I find the right one. Can anyone suggest any voltages to measure or any other things to look for. Under normal driving conditions the car is fine, it accellerates fine, only when stopped at the lights does it act this way.
Appreciate any pointers,
Max
Max
