1 - 20 of 42 Posts
hey guys im changing my oil for the first time..its a big step for me..but i cant locat e the oil plug...if i cant locate that plug would it make any difference if i just remove th efilter and let the oil drain from there?
The oil plug is on the very bottom of the engine oil pan, on the passenger side of it. It will look like just a bolt head. It takes a 13mm wrench or socket.
Just dropping the filter will only get the oil out that is in the filter, which is a quart or less. The drain plug has to be pulled.
well..there are more than one bolt at the bottom of teh pan..im prolly gettin confused with the ones that has it attatched to teh car...but there is on that is screwed in sideways..that was probably it..well i went for that one and i balled it completely..so i guess imma have to take it to the ealer tomorrow!
i shoudl have taken a pic...ill attempt it again tomorrow...thanks to...there are more thna one plugs down there thats why i got confused yano its my first time attemting that..thanks anyways :)
A pic
Here you go, looking from under the front of the car:
Yup!....thats the one I balded...
You mean rounded off? Don't go to the dealer, go to the parts store and get a new drain plug, and a set of vice grips. The vice grips should allow you to break the bolt loose. Once you get it out, replace it with the new one. If the vice grips won't work, a small pipe wrench will almost certainly get it out.
Discussion Starter #11
LoL..i think i balded it bcuz i was screwing it the wrong way.... Is it clock wise or counter clock wise to screw it off?
Just make sure that if you do it yourself, that you put the screw in very straight. Our cars have an aluminum pan and it's easy to stripped the thread in the pan and then you'll need a new one....
lefty loosey....righty tightey and when you put on the new plug make sure you rub a trace amount of oil on the threads so it dont lock up next time you do this. also do the same on the filter
Discussion Starter #15
dang..i shud have know this earlier lol..am gona have to purchase a new vice grip 2moro
Try it out you got nothing to lose. They can't charge you extra unless they ask you and you agree. Happened to me at CT they charged 20 extra for "rim cleaning" when I put my summer tires on and I started bitching about it, got to talk to a manager or whatever they are called and he removed the 20$.
1 - 20 of 42 Posts
