My climate contol panel is not working....no heat /AC/defroster,
yet my fan works. Is there a fuse in the climate control panel ?
Any help would be great !!!!!
Have you removed the interior trim peice lately? The one that holds the climate control? You might have just unplugged it from the back or something.
Manual control head or Automatic temperature contro head (ATC)? Does the display work? If it's ATC and the fan only has high speed it's probably the ATC blower motor control module.
While you're at it Intreper sells some sweet billet knobs for the control heads. ;)
It's not ATC and i changed the fuse {it was ok}. Does anyone if theres a fuse in the panel it self?
Thanks for the Help
