My cv axle on my front right sided pop off on my 1993 Ealge Vision Tsi with a 1996 trans. The axle is only $150.00 can any one find it at a lower price? And will this miss up my trans? :gross_07:
How did the axle pop off??!! Do you mean that one of the joints went bad, causing it to pop off? If so, sometimes they sell kits where you can replace the joint bearings and the end spline and don't have to replace the whole axle.....not sure about your make and model though....
Do you live in canda? The last halfshaft I got was $60. There was also a $60 core charge, but I got that back. If it has ABS I think they run $75. I got those at Oreillys. If you have one of those around check with them.
Thanks Guys!!!!!!!!!!!!
I live in PA and the axle pop off when my car was trying to park in the snow. The snow was no more then a half a inch. But before that I would hear a poping sound when I first would start the car and make the first turn. So I guess it was going to go at one time or another. The core is still in the trans and so is the other part that goes to the front wheel. Just the middle part poped off. And it is ABS, and I think my core was $60.00. I just hope my trans is ok :flash:
