Hey Randy or whomever. Here is a updated vin decode list for the vin decode section.
LH Vehicle VIN Decoder
Position Interpretation
Code = Description
1 Country of Origin 1 = Built in USA by Chrysler Corp.
2 = Built in Canada by Chrysler
2 Make B = Dodge
C = Chrysler
E = Eagle
3 vehicle Type 3 = Passenger Car
4 Passenger Safety B = Manual Belts
E = Active Restraint, Passenger Airbag H = Restraint System, Active Driver and Passenger Airbags
X = Driver Airbag, Passenger Manual Belt
5 Model C = LHS (2G)
CH = Concorde (2G)
CP = LHS (2G)
D = Dodge Intrepid (2G)
C = Chrysler New Yorker/LHS (1G)
D = Dodge Intrepid (1G)
X = Eagle Vision
Y = 300M
D = Chrysler Intrepid (2G)
L = Chrysler Concorde (1G)
6 Series
4 = High Line
5 = Premium
6 = Sport
7 Body Style 6 = 4 Door Sedan
8 Engine
F = 3.5L 6 Cyl 24 valve gasoline (1G)
G = 3.5L 6 Cyl 24 Valve Gasoline SOHC Alum. Block (2G)
J = 3.2L 6 Cyl 24 Valve Gasoline SOHC Alum. Block (2G)
R = 2.7L 6 Cyl 24 Valve Gasoline DOHC Alum. Block (2G)
T = 3.3L 6 Cyl Gasoline (1G)
U = 2.7L 6 Cyl 24 Valve Gasoline DOHC Alum. Block (2G)
V = 3.5L 6 Cyl 24 Valve Gasoline SOHC Alum. Block (2G)
9 Check Digit 0 thru 9 or X
10 Year
P = 1993
R = 1994
S = 1995
T = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
11 Assembly Plant H = Bramelea Assembly
12-17 Sequence Number 6 Digit Number Assigned by Assembly Plant
Also if anyone has a question about their cars VIN info let me know and I can decode your VIN for you.
p.s. I can decode it at night from home also.
