1 - 2 of 2 Posts
I have a 1999 intrepid 2.8 only 72000 miles on it, I have a problem with my heating I only get cold air through the vents, I have changed the actuator, bleed the cooling system and both hoses going in and coming out of the heater are hot, can someone shed some light on this
Thank you
Welcome to the forums!
Did you put the control unit thru a self-calibration after installing the actuator? Since your hoses are hot, have to wonder if the actuator/door is not working.
If you used an aftermarket (Dorman) actuator, that is probably the problem. Nobody has had any luck with those.
Do you have MTC or ATC?
(You obviously meant 2.7)
1 - 2 of 2 Posts
