1 - 20 of 21 Posts
>How much of a difference do you think one would notice after changing it?
About as much as adding ¼ lb of air to your tires. It's just not going to be anything dramatic.
Thanks for the answers.
Should I change it per manu scheludely or leave it as is?
Thanks again.
If you have never changed it, drain it out, and put in some Mobil 1 75w90. That should last you a pretty long time.
Should I go to dealer or change it myself? Thanks
Why does Chrysler specifically state not to use synthetic in the differential? I would assume the synthetic can only perform better than standard oil.
I got mine done at some speedy lube place but i'm going to try and pick up some of that mobil stuff and do it myself after winter :)
Any idea how much 80W90 one should buy in order to replace the differential fluid?
I believe it holds a qt. I have Amsoil synthetic diff. fluid in mine and have also installed the vent tube fix. Just my $0.02.
FredB
Chrysler does say not to use synthetic diff fluid. But many have anyway, and I haven't heard of a single problem.
Car Quest has limited slip 80W90 and 80W90 that can only be used to top off limited slip... what's the difference and what should I use?
Maybe I should change mine. I have just over 68k and never changed it.
Hmmmmmmmm.....something else to do in the spring I guess.
front pads and rotors.....check
struts on all four corners...check
diffy fluid....check
finally get to install some of my mods...check
Damn it! Won't spring get here!!!
I asked the lube place to do my diff fluid today while I got the oil changed, and the idiot told me I didn't have a differential since the trep is FWD. Duh.
The scary thing is, I then let him change the serpentine belt for me. :doh:
Dave
Yes, it DOES have a differential...even though it is a FWD car! Good thing they didn't do it then, since they obviously are clueless! Find someone who knows what they are working on!
Another reason for DIY! Reminds me of the time I bought some snow tires at Sears for my 66 Toronado. Hade a hell of a time getting the idiots to put them on the front. Just my $0.02.
FredB
Mopar or No Car
FredB
'66 Toronado - did they really make them that early?
I know what you mean, though - numb-nut SOB's think they know your car better than you ... :soapbox:
That is now in my top 10 list of funniest things I have ever heard lol, well I don't have a list... but If I did :)
1 - 20 of 21 Posts
