Hi all,
Just last week I replaced my EGR Valve (had DTC32). After I put the new one in I have been experiencing abnormally high idle. When I start the car in the morning it races to 1500 RPM. Once it's warmed up it is at around 1000 RPM. Could this be a leak in the EGR Tube? I will be checking that out tonight after work. Any suggestions would be greatly appreciated.
On another note, this morning on my ride into work I noticed that my gas light was lighting up. Looked at the gas gauge and it was reading 3/4 tank which is right. Then after watching it for awhile it would dip and the gas light would light up then it would return to normal, dip again, and so on. It did it at lunch too. What could this be? It was fine yesterday. The only difference between today and yesterday is that it is raining today. Could there be a loose connection or is my fuel sending unit starting to die. The car is still running great though. I just had the fuel pump replaced and they took out the relay to bleed the pressure from the system. Could it be that relay? I would think that the car would suffer some performance issues if it was the relay cutting out...
Anyway, Thanks in Advance,
Kyle
[ June 21, 2001: Message edited by: swartlkk ]
Kyle
