32Intrepid said:I take the upper plenum off and use the intake manifold bolt holes. With the plenum off, theres much more room to get to the fuel and heater lines at the rear, and the engine to trans bolts.
OldSchool said:OK, the FSM does say to remove the intake plenum to avoid damage...that probably the way to go.
Thx for your input...
98_2.7TREP said:Did you take out everything including your transmission and catalyc converters?
