I had a '00 3.2 replace my '99 2.7. The engine is sitting higher than it should and the hood doesn't close. Any suggestions? I used both mounts of the '00 3.2.
Well seems as we are in the same boat, huh? Are we the only 2 that have had this problem? How are you managing to shut it?
My hood is able to close but it does not close all the way down I am taking it to dodge to see what they can do I am going there also to make sure every thing is in the right place and connected since my swap
Mine did that at first,All I had to do is lower the clasp that the hood locks into on the front,also make sure it is centered.
I couldnt figure out what the hell to call it, yea that thing! I also used both the rubber mounts off the 2.7.
