Okay, had a MTC for 150K, so now I have ATC on the M that blew the evaporator. (oil out the drain line)
So how do I get outside unheated air out of the vents? All I can do is get hot air and lots of it! It was raining on the way home tonight and I needed the defroster. Just warm air would have worked but, noooooooooooooo........ This thing was full bore volcano heat!
Is this in the M or the Intrepid?
Have you tried the ATC calibration procedure yet? Especially if you've had the battery disconnected previously for any reason.
No, i did several weeks ago after recharge. It worked. Then i slowly lost the charge, tried recharging and it blew the evap all over the floor. I lost the instructions I printed from the FSM. Need to look that up again.
There's a sticky for it at the top of the 2nd gen general discussion.
