What's it doing or not doing? I have a 96 3.5 in the driveway I can look at with you.
Sent from my SM-G996U using Tapatalk
I have a wiring problem on my 1996 dodge intrepid 3.5 liter!! my computer not reading right for a wiring problem on my vehicle. I already had a mechanic look At it and he said it’s a wiring problem
What's it doing or not doing? I have a 96 3.5 in the driveway I can look at with you. I just got a new computer and my 3 and 6 cylinder not firing. But the computer not reading one of the cylinders that’s not firing the mechanic said it’s a wiring problem Sent from my SM-G996U using Tapatalk
I just got a new computer and my 3 and 6 cylinder not firing. But the computer not reading one of the cylinders that’s not firing the mechanic said it’s a wiring problemWhat's it doing or not doing? I have a 96 3.5 in the driveway I can look at with you.
1st gen doesn't have individual coils does it?Was it firing off the old computer?
Have you swapped the coils for 3 and 6 with two other cylinders to see if the issue followed the coils?
Yes sir! All those things was doneWas it firing off the old computer?
Duh.1st gen doesn't have individual coils does it?
Yes that and a compression test was doneI change the coil pack, wires and
Plugs!! But, it still do the same thing i also charge out the computer.
