first I used an air gun to blast all the dirt away
or just huff and pufff if you ain't goott that
I used a high tech big yon 'kin flathead screwdrivwer with a 24 inch handle length
I pryed it gentllllllly till it seperated from the block and then Ipulled out the sensor.
put a dab o penziol high pressures grease on the new sensor o ring ---- and gentle replaced the new sensor into the old
cleaned out location :alien:
aviation, have you checked your battery as suggested?
if the code 54 is actually a true code, the engine will still crank when you try to start it.
