Status
Not open for further replies.
1 - 1 of 1 Posts
There was a thread Aug 2009 explaining this from DBAKERPARKS, but, how do you remove the inlet tube from the housing? The heater tube runs between the heads, so, you wouldn't be able to pull the inlet tube out of the water housing, which means you have to push the water housing backwards once you get the screws out? WIth only propping the intake manifold up, is there enough room to push it back?
Boy, since this is such a common problem, would be nice to have a how-to on this.
1 - 1 of 1 Posts
Status
