1 - 20 of 28 Posts
This is pretty low if you ask me.
Here is the pic
[ November 18, 2001: Message edited by: blkbute ]
you need a sticker in the back of that car that says, "Too low for fat hoes" :D
That looks bad, I wish I could lower my car that much. O.K. maybe just a little bit higher :eek: :eek: :D
Discussion Starter · #6 ·
if I had the $$$ to put into this ride. Then I would get air bags forsure. Have the highest hieght as the stock, and be able to to drop it down that much. Your car will never get towed. LOL. :D :D
that actually doesn't look as bad as i was expectin.
he can use it to ride around and flatten out the grass in an area if he needs too.
That is low, I would do the same get the air bags, and the drop it when parked. imagine the looks...
I dont know much about suspension so bear with me here, how much do those "air bags" cost? and can you put them on any suspension or do you have to make it all custom?
Discussion Starter · #11 ·
hmm, I do not know. prob 3 times what lowering springs would cost. but you can move them up and down. So thats a plus. They make them for 300M. On sound domain there is a guy with a 300M with Dubz and airbags. nice ride.
I do believe that air bag suspension is pretty much a custom thing. yes, there is a 300M that has done this, but they dont make a "kit" for LH cars, this kind of things needs fabrication of parts, welding, etc. So one con is, if you dont like it, too bad, its permanent. I would like to do this to the trep as well, theres just something about pulling up to a parking spot and going "swhoooish" and dropping to the ground. I dunno if ill ever accomplish this, its kinda non race, as well as extravagant. But, mabey....
Discussion Starter · #13 ·
you can even do it cruisin the strip, the car will be soo low you could not turn the car. But you will be able to keep it in a straight line.. it would just be crazy cool.
yeah, i think that kind of suspension would look sweet as hell!
hey, my car really is that low!
Discussion Starter · #16 ·
Eibach will not lower it as low as that.
Discussion Starter · #17 ·
Wutang has the Eibach kit if Im not mistaken. here is a pic of how low is car is. If you notice he is not up under the wheen wells, in the pic I edited they are soo far up you would not be able to turn the wheel.
Wutangs car
[ January 28, 2002: Message edited by: blkbute ]
:eek:
this just brings me 2 questions in mind:
1) do you scrape the car while going up or down a exit ramp on a freeway?
2) what's the biggest speed bump your can take climb over now and how slow do you have to drive over it not to scrach the entire belly of the car?
Discussion Starter · #19 ·
the car does scrape quite frequantly, and speed bumps take some good time, some I just do not even try. No just kidding its a photoshoped pic, I jsut lowered it to see what she would look like super low.
no, really my car is almost that low, the undercarriage of my car is about 1 and 1/2 inches off the ground in the lowest spot.i got eibach springs, then had them heated. ill post pics as soon as i can, i do scrape all the time,i know its not good, but i cant "undo" it now. plus it looks bad as hell.
1 - 20 of 28 Posts
