The proper way to do this mod is to use a soldering iron as well as heat shrink tubing and correctly route the wires. This is more of a proof of concept.
Step 1: Find a donor from the yard, and separate the backing from the shift position indicator strip.
Step 2: Drill suitable size holes for the LEDs. I used 5mm LEDs with resistors already pre-wired and glued them into the holes.
Step 3: Wire the LEDs to the factory switch.
Step 4: Insert into bezzel.
Finished product
Ah clever. I removed the EL sheet from the decorative face, and ended up creating a backlight from tin-foil and two LED's, worked but eventually fell apart with all the times I took the console apart.
Nice job and look. Is the black box/inverter needed for LEDs like it is for the EL?
Scarce911 is working on my shifter strip, but has gone a different path in doing it. When he becomes active again, maybe he'll chime in/post pictures of it.
