1 - 2 of 2 Posts
I am installing heads on a 2000 dodge intrepid. I was wondering if anyone knew how to set the timing in it. I need to know how to set the cam to cam timing and the primary timing chain.
Download the factory service manual below: It is 2002 version but timing and most everything else is same for 2000
http://dvms.dvusd.org/02lhe/
Section 9 has complete timing instructions
page 9-83 has a good diagram that should answer your question.
As long as you have the crank lined up perfectly the rest of the procedure is pretty much just making sure that the colored marks are in the right places.
good luck!
1 - 2 of 2 Posts
