Hp has been no help so far and this **** is driving me crazy. I have built two computers and never had a problem like this.I tried installing the printer their way, the traditional way and nothing works. My camera and my canon printer will work on the same cable and port but not the HP printer. It always says at the end- There was an error printing-Problem printing to the port-Make sure your printer is configured to use a valid port. I'm going to start drinking again
Any ideas
Will the printer do a self test?
Will it work off a parallel printer cable?
If the 960Cse is the only USB device hooked up will it work?
What OS is this?
HP is of no help, say it isn't so! Bunch of rude freaking morons if you ask me.
It won't do a self test, It will work with a parallel port. No it wont work even if it's the only usb attached and it's Win 98.
If it'll print to a parallel port it should self test. Turn the printer off & hold down the power button when you turn it back on.
Is this Win98 or Win98se?
Did you get the latest drivers?
