1 - 20 of 24 Posts
this was them when i first bought the car, after a few washes it gets even worse, today i power washed them and it peeled a ton of it off.
i was curious to what kind of spray paint i should use on them, if i should use spray paint,
maybe some type of latex paint then put a clearcoat layer when dryed?
Honestly, I'd take a trip to your local wreckers to see if they might have something... Granted it won't be as inexpensive as a rattle can fix, but might be simpler...
Having just painted my plastic rear pillars on my 97, plastic can be a pain in the ass to paint...
Well if you look in my sig, those are painted black ES rims. I basically sanded them down, then hit them with Duplicolor wheel coating, satin black and clear. I think the same thing works with hubcaps, I'm not sure. Whatever you would use, make sure it's good for high heat.
yeah idk if it will work the same because the hubcaps are plastic, thanks though.
after doing a little research they do have hubcap paint, as far as quality idk, i might be better off using a different kind of paint with a clear coat.
i didnt even take into consideration the heat tolerance thanks reggi = D
alright thanks
whats the reasoning behind wreckers have something? just curious
Well you might be able to pick up a hub cap for about $10-15, that's all. If you do decide to paint, clean them really well. Fish eyes appear like crazy if there's any brake dust, silicones (from waxes, tire cleaners, etc) and road grime.
Heat shouldn't be too much of an issue. If it were, you'd roast your hands on the rims after a drive. At the most the hub might feel warm. If it's hot enough to burn paint, you've got bigger problems (ie siezed caliper, dry hub, etc). I've painted badly oxidized/corroded aluminum rims with regular RC white and never had any issues other than the fish-eye issue, even after cleaning, but the aluminum was in rough shape though.
Hence the easy way out by hitting the wreckers for a cheap, labor free hub cap :D
i did a set for my stang a few years back for winter, i used oven cleaner to remove old paint didnt harm the plastic then hung them and hit them with a rattle can.
i did a set for my stang a few years back for winter, i used oven cleaner to remove old paint didnt harm the plastic then hung them and hit them with a rattle can. thought you had rims on your car john ?
Yeah, I added the part you removed/edited out. I did the wheel painting way back when I had my 92 Z24... Old aluminum Breretta GT Rims. (at $50 for a set of 4 I didn't care what kind of shape they were in LOL). Mine are the polycast rims right now, for now ;)
Forgot about the oven cleaner tip.
I painted my hub cap that I use as winter caps, instead of my chromies.
They held up good for a whole winter so far. I used duplicolor and painted after sanding. I followed with clear coat. They match the car and look good. The centers I painted with color changing paint. Holds up good.
I painted the hubcaps on my buddy's Taurus with krylon fusion. Worked quite well, and has held up well. Its paint made for plastic, thats why I used it in the first place.
I painted mine(exactly what you have) though I had it done in a more professional way. I sanded them down myself. Took forever. Was about 30 minutes at least a cap. Then they where sprayed with some silver paint and then clear coated. The didn't turn out to bad at all but some of the clear ran. It is possible but after all was done I think I might of just bought some off line even though they usually don't use the same thickness and use a cheaper material then stock.
if you cant find a junkyard with those hubcaps, go to the hubcap and wheel store. its on st. charles rock road in bridgeton
Yeah, those fortress hubcaps are a problem with the paint. My brother's 97 Trep has those hubcaps. I took them off and sanded them a bit and painted them. They look a bit better, but I think the paint is starting to flake again. I would say the best bet is to repaint them yourself. Chances are that you would run into the same problem with junkyard hubcaps.
Personaly i think rollin on just blacks with no hubcaps looks better then rollin with new hubcaps.. Just get a set of nice rims and toss the cheapo plastics in the trash man :)
Discussion Starter #19
I think I used light or bright silver by Duplicolor of course primed them first using Duplicolor gray primer. Usually you can find those at Advance, Autozone or Wal-Mart.
has there been any peeling or fading yet? im prolly gona clear coat mine so they last longer....
somebody mentioned something about priming it... r u even supposed to prime plastic?
1 - 20 of 24 Posts
