I have a few fault codes, i think i found the answer to one, but the code 32 and 33 confuse me. i looked them up, one is a ATC mode door failure (WTF) and the other is ATC blend sumthin or other failure (WTF) what do they mean? the car still runs like its a brand new car, but its throwin codes.
oooohhh... ok lol. i feel like an idiot then. i dont have any of those. i took my AC out today. so the only code i gotta concern myself with is the 51 which is a lean condition, but like i said i think i got the answer to that already.
Hold on !!! Code 32 is your EGR valve, and Code 33 is the A/C Relay circuit. Code 32 could cause a lean condition.
ericcole said:
any idea on how lean?
LOL, there's know way I can till you how lean your engine is running. Maybe some of these threads will help you know what the EGR does:
http://www.dodgeintrepid.net/forums/showthread.php?t=60322&highlight=EGR+Valve
http://www.dodgeintrepid.net/forums/faq.php?faq=new_faq_item_1stgen#faq_1gcode32
As you read these threads, you'll see that a bad EGR valve, will make the PCM read from the O2 Sensors that the engine is running to lean. If the o2 Sensor is out of a certain range, it'll throw the 51 Code. You can also search the forums alittle more on a code 51 and code 32 too.
well ive had the cod 32 ever since i ripped my EGR stuff out. but it never said anything about a lean condition until a few days ago. it did it just after i changed my rear O2's i think i may have plugged the O2s into teh wrong plugs like i got hem switched around. could that cause the lean condition? ive had the EGR delet for no tellin how many weeks now, and it has never thrown a code cept the EGR malfunction code. some one told me that havin the O2's switched around could have caused it.
atleast it hasnt caused any running problems. no stalling sputterin or knocking or anything like that. it runs great like always.
