ican i plug only 1 coil on 4ohms dual voice coil-2x4=8 ohms for 1x4=4 ohms.I have 2-4 ohms: amp.ultimate t3-1000D and 2sub 12po Pioneer 1200w DVC 2x4ohm ,one is burned...
Is it a mono amp? or (2-4-5-6) channel amp?
What amp and sub do you have?
Specs would be help full to add a lot better answer
The answer is yes but... might need some specs on your equipment if you want detailed info :)
ultimate t3-1000D amp and 2 sud pioneer champion DVC 2x4 ohm but one sub is burned so can i plug 1 sud like a SVC 1x4 ohm to my amp for have 4ohm?
So if Im understanding correctly all you want to do is connect your dual voice coil sub to your amp?
