Update:
2nd day after installing light switch and climate control car started. However, after driving car today and turning it off, the oil light and transmission selector light stayed on. Also, when jiggling the key in the switch, the oil light flickered. I got the lights to turn off by starting car and turning off a few times and then removing the key.
Someone in another post on this forum reported same problem and it was speculated by some (peva, daytrepper, micholob) cause likely a bad ignition switch (see below)...so my next step is to replace it.
www.dodgeintrepid.net
The OP in that thread, like many others, didn't post outcome of problem he reported...very irritating.
Oil light on when ignition is off
So a couple days ago I noticed my oil light comes on after I shut the car off with the key out of the ignition. I can try and put the key in, cycle it, and it doesn't go back off. After a while the light does go off though. Also, it's not fully lit like when you start the car, it's dim. It was...
