1 - 17 of 17 Posts
im having a multi missfire prob with my 2001 dodge intrepid...its doesnt spark all the time or just get's a low spark
get off my lawn
yes it is..wouldnt that be the first thing to check if something was wrong with your car...
yes it is,, need to get the codes, do this,, turn the key , on , off, on , off on, off, on,, then look where the mileage is,, it will take a second it should say something like po300, po659. po440, something along thos lines
when doing this , do not start the car , just turn on and off,, let us know
Grab Your ***** By The Horns
What Dr. Dodge was explaining above is, with your key in the ignition, without actually starting the motor, turn the key to the ACC position (just before start) and back to OFF three times (3X).
You should hear a chime(s) and then look at your odometer. It will display one or more four digit codes before showing "Done" then returning to mileage. These codes displayed will enable someone here to look up their meaning and try to assist you further.
Good luck and welcome to the site!
If the procedure was done right, it always ends with 'Done' where the mileage is. Try the key dance in netural instead of park. That's what I had to do the first time.
Off, on
off, on
off, on
leave it there. don't start the car.
Late!
the codes still didnt pop up i put it on a scanner and it says intermentin miss fires..the car sparks a few sec's after u crank it then it goes off agn...i thank you alll for the help so far your greatly appreciated
get off my lawn
ok,, if you put it on a scanner it should of shown codes on the scanner,, but,, im almost thinking you may have a bad cam sensor,
1 - 17 of 17 Posts
