1 - 13 of 13 Posts
Porsche 914 gauges
White leather interior
275 tires in the back...whoot
clarion cd player..and custom 4" kick panels..i made..*Fiberglass*
WELD RACING WHEELS
1600CC 60hp powerplant....modifictions coming soon!!!
custom 6x9's in the back
Got some body work done
BEFORE
AFTER
BEFORE
AFTER
Transparent yellow distributor cap
BEFORE
AFTER
GAS SHOCKS
ELectronic ignition, high performance ignition coil, yellow spark plug wires
j tubes...eleminates heat...MORE HP!!!!!!!!!!
EBAY SCORE
Dain bramaged
makes me miss my 71 super.. I'm pullin her outta mothballs this spring and gonna go nuts with it..
why all the custom work and a stocker engine thou?
oh btw, those tranlucent caps look nice, but suck ass, i used to carry one for shows only..
thou at night it was fun to watch the spark and it made diagnosing a miss easy
its not completley stock..it has a 34 solex carb and a high performance fuel pump..for when it used to race...i plan to build it to a 1776cc...i dont think ill go any bigger...im only 19...and still learning
Sweet Bug, Cobie!! In another thread, you mentioned bringing it to Forest City next year. I hope you do...I'd like to see it. Of course, How you gonna get the Bug and the Corde both to F.C.?
ill get a hidden hitch
Dain bramaged
I had j-pipes on my last motor, one fell off and i ran it over.. which sucked..
i have a dual single carb setup, rear pop-out windows and one peice front glass in my shed still..
1776cc. 90.5mm cyl/pistons I believe. swapping jugs is pretty easy. you have to split the case to swap the crank and change the cam which is not a lot more work if the motor is out anyway. increased cubes is nice but you never know what cam is in the motor now. and you also do not know much about the heads. i would hope you have dual port heads. but you never know. might be vintage single port low hp parts. you should check to see if there are any VW performance shops in the area. pretty hard to find now. not a lot of old bugs left. you could swap on a set of mildly ported heads that would really wake up the bug.
im learning more and more everyday about it...i have about 4 books and 9 million magazines...tryin to learn as much about this car as i know about the corde...
im having fun though...car runs like a champ..not going to do a rebuild untill i have too
no thanks
Discussion Starter #13
Just won this on ebay for $41...i think its great!!!!
FYI..its a rear engine hood
1 - 13 of 13 Posts
