1 - 2 of 2 Posts
Can anyone verify for me that the sail speakers are same part # and power rating when used with the 240 and 360 watt amps?
I can't say they are based on part numbers, but they should be identical between the two systems. The extra power from the 360W amp is for the additional rear door speaker channels. So if you're not using those you're not getting any kind of upgrade to your system...
1 - 2 of 2 Posts
