I managed to find a 00 300 M in the junkyard with all it interior still intact.So over the last 2 visits to the yard I striped the whole interior except the dash.In one of the trips I pulled the entire infinity system with all the wiring and speakers.I got everything installed and wired in my 00 Intrepid,that had the base audio(no amp) just fine.Everything works except the sail speakers.I have double check all my connections and everything it wire to factory specs.So any idea why only the sail speaker don't work.Could this be a possible amp problem.The amp it the 9 channel one and the only speakers I didn't use were the rear doors and the center dash speaker.
The Midline audio systems in the Intrepid have different wiring pin outs off the amp for the Sail Speakers vs the Infinity I & II.
You say you had the Base Audio with no amp. No Base system had Sail Speakers. So did you add the door wiring for the Sail Speakers? Next question is whether you pulled an Infinity I or II system from that M? An Infinity I system will have an amp in the passenger side kick panel under the dash...just like an Intrepid would if it was equipped with it. An Infinity II system has the amp in the trunk on the passenger side wall. Those were weren't available in Intrepids.
Need to know which system you got before trying to help you out.
I pulled it from the trunk,and yes I ran wires to the doors to power the sail speaker separate from the door speakers
OK...so it's an Infinity II System. What wiring diagram were you using to get everything connected? What year/model?
I downloaded the manual after doing some searching on here and finding a link for it.The car is a 2000,the 300 was a 2000.I pulled the wring from the trunk all the way to the dash.I then used the extra wires that were for the rear door speaker to extend the wires to reach the radio.I then cut the 8 wires at the radio plug that were for the speakers.The side going into the dash harness I soldered the amplified speaker wires.The wires coming out of the radio plug I soldered the wires that feed the amp the sound from the radio.the I had to run 4 wires to the front door for the sail speakers.The yellow/red:yellow black to the driver side and the orange/red:eek:range/black to the passenger.All this wiring took me almost a day to do but I made sure to get everything matched up right,which is why it don't make sense that everything works but the sails.
