My used 2006 Durango Limited has some glitches with the instrument cluster. The TPM light is on yet this feature was not available for the 2006 model. Also, the "Cargo Light" for the rear hatch stays illuminated even after the door is closed. This light does eventually go out after 2 or three cycles but always comes back on with subsequent hatch openings. I believe the instrument cluster was changed due to a recall concerning a fire hazard from over heating. I'm hoping a dealer can reconfigure the cluster or reprogram the BCM to address these issues. If anyone has any info or insight regarding this problem any help would be greatly appreciated.
trembuzz
Cant remember for sure, but if the 2006 models have the TIPM module, likely that may be the cause; it is a BCM of sorts. They had alot of trouble with them. They started using them around 06-07.
The cargo light could be in the switch in your tail gate.
