Oy guys, yesterday I decide it was time to do it so I change the intake gasket.It took me almost 8 hours to do it. Ok I took my time as I want to do it right. So I took time to labeled all the electrical connector and vacuum hoses.Plenum was quite easy to removed.When I look at it,I discover 1 of the 2 holes in the back of it (where the EGR tubes are bolted) was completely block by some grim..So I take time to clean that. Then I decided to remove the thermostat housing to get room for the fuel rail, I was taking the opportunity to change the thermostat as I got a code for it. Man! when I took it off , I found it completely crushed ! The termostat was in pieces !! Next fuel rail. Again quite easy to unbolt and swing out of the way. Thanks that I had removed the thermo housing. Next the intake itself. Also quite easy.No jammed bolt anywhere. Removing the old gaskets is time consumming but it had to be done perfectly. After I put back everything in place, change the thermostat, fill the reservoir with new coolant I start the car.It idle supperbly now! No more dance of the RPM everything was good. So I decided to do a road test in town. Temp get to normal position, halfway between hot and cold ( which it never did before:was always on cold even in the summer) and idling was perfect. I then took the highway and after 5 minutes the temp needle jump to the hot position and then the temp light went on. So I stop the car and open the hood: there was coolant on the passenger side of the engine compartment but not on the engine. I tried to find from were it have come out and the only place I can see is the overflow from the reservoir.
What is wrong? I heard about that air in cooling system? Can it be the cause? What can I do?
