The spring is built into the switch itself. Doesn't seem likely to break, but possible. Grab both sides of the maplight and pull straight down to take a look. (Maplights are held in place by 2 compression brackets). The switch will just pop out from the Maplight bracket for examination. If you need a new part, I can help you out for cost of postage. PM if you'd like.mrcmplx said:Hello all,
Im in need of some help with one of my overhead map lights. The light still works when I turn the switch but I think I busted the spring in it.
Can someone help??
