I believe the fronts will bolt right up, but the backs will require a tad bit of modding to fit into a first gen, but it can be done, cause YB Normyl had 300M seats in his EAGLE Vison, before he got his SXT.
Thanks, I think the only problem with the back it the back of the back seat being higher than the other.
The back being higher creates a problem for the seat belts to retract, the hooks for the seat back as well as the bolt holes at the bottom are different and the arch of the wheel well is also different. Nothing that can't be overcome. Oh almost forgot, you need to swap the frame under the seat cushion with the 1st gen one.
