1 - 2 of 2 Posts
my neighbor has a 2000 intrepid with 100+k on it and is having a problem with and intermiten no-start problem; some days it will start right up fine nad other days it will not start no matter how long you crank it; it turns over but just doesn't catch; changed some relays/fuses but doesn't seem to matter; the fuel pump in tank? makes a little bit of noise which leaves me to believe it is working; haven't checked fuel pressure or anything like that yet. On the days it does start up it runs fine, nice smooth no hesitation. baffled for no though??
Crankshaft and camshaft sensors are a common problem on these. Do your basic checks when it wont start, fuel, spark, and compression. If spark is missing, crank or cam sensor, fuel is missing, relay, pump, or auto shutdown relay. Check compression last. If it is low, and with the notorious 2.7, internal engine problems exist.
1 - 2 of 2 Posts
